dude 3.4 bug
Hi all.
In the network Map I inserted 6 static elements (and approx 100 devices).
I select this 6 static elemnts, i selec Settings then I change color: all map elemnts disappear from map also if there are in device list.
Have someone a workaround ?
thanks
What do you mean? You just can’t see it, because they become same color as background, or they deleted?
