Dude 4.0 beta 1+2 and "\"
I made an update from version 3.6 to 4.0 beta2 and some functions give back “parse error”. The same I also had with beta1 in the past. Now I found the time to made some investigations. It seems that the new versions of 4.0 do have problems with text elements included a backslash. For example:
if(2>1, concatenate(“\”, “test”,""), “false”)
gives back: “parse error”
if(2>1, concatenate(“\\”, “test”,“\”), “false”)
gives back: "\test"
(version 3.6 gives back: “\\test\”)
After adding one "" for every "" in version 4.0beta2 my functions are working again. Maybe there are also problems with other special characters.
Bye
Due to no answers, I am not sure if I am the only one with this problem. If not, it would be good to know if Mikrotik will work on this, so that all functions/probes from version 3.* are fully compatible with 4.*. In this case, I will wait with upgrading for the next version :wink:
Bye
You are not the only one. Some things are changed, but is it a problem?
All you need is to check if all the functions and probes are working after update and change it, when needed.
Of course it is not a big problem. But if I had the choice to change all my affected functions/probes, or wait for a corrected version. I will choose no. 2 :wink:
Bye
I’m not from Mikrotik staff, but it seems in this case you will wait forever. :slight_smile:
I do not beleive they do consider double slash to be incorrect in functions.
