I have a problem with my dude , it stop working now when i check the this command here is the result:
/dude print
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
so i download the database and delete all historic data it reduce the database size from 260MB to 20 MB
but still when i enable the dude and run the /dude print it shows it is loading the record and then it hangs again(check the attachment)
it seems there is a line in database which crashes the dude
when i dump the database i have 43427 records in obj table
