Dude 4 and Xubuntu
Is it possible to run Dude 4 beta 3 in XUbuntu using Wine and the Mikrotik’s Wiki procedure for Dude 3.5??
I want to run it over a ODROID-U3 :smiley:
Thank you so much in advance,
Marcos.
try it this is the best test.
Wine works with winbox i think that the dude also works with wine but not yet done
I’m running the dude 4.3 beta in Debian 7.4 under Wine 1.4.1 without issue.
For things like winbox, you’ll need to install the microsoft fonts for some things like the terminal to look correct, or you could just ssh in. I didn’t notice any other issues.
Long story short: install fonts, works perfectly.
Where can i find this fonds?
Thanks for reply
On Ubuntu I install ms-fonts with this terminal command
sudo apt-get install ttf-mscorefonts-installer
isn’t odroid some ARM machine? Dude is x86 software, so, it cannot run even you have XUbuntu…
Another thing is, that Dude normaly works under wine on x86 machines…
