Dude 6.20
How to install dude on MikroTik MT RB2011UiAS-RM?
Current npk package do not include dude.
How can I install dude npk package to run Dude and connect to the router?
It is not supported. Mikrotik allows to remove dude on 6.20. It is not good idea to run dude on ros anyway as it doesn’t work properly. Run dude in Windows instead.
Thx, but My Windows Dude did not recognise my network.
Only router but I don’t see any of devices connected to the network.
Same issue I have.
I am adding new devices manually and it works good. Are you talking about automatic map creation? I don’t use it as I consider it not needed. Or what problem do you have with network recognition?
I’m glad that this problem occurs not only for me.
The problem is that after scanning my network I getting only my Mikrotik router address.
I have additionally more than 20 devices (switches, routers, NAS, any other devices but scanning did not recognise …)
I don’t wana add manually that all stuff.
What I should do to scan all devices properly ?
But if you do add the device manually, can the Dude ping it and scan it ? If not, you have some firewall somewhere
Mikrotik Router is added, scanning process finish properly but without any results.
Do it manually as 20 devices is like nothing.
Right, this is possible but why this is not working automatically ?
Workaround you proposed ;-( ,
but I’m asking for support and advice :wink:
There is no support for Dude. Accept that.
Accepted ;-(
Dude forgotten ..
Only by mikrotik. Others are using it…
