Dude 6.36 on CCR1036 hight cpu and disk usage
Hello. Watching 100% CPU utilization on two cores and disk usage.
CCR1036, ROS_6.36
if i set enabled=no, i see this
[admin@MikroTik] /dude> set enabled=no
[admin@MikroTik] /dude> print
         enabled: no
  data-directory: dude
          status: applying settings: disabling: waiting for config changes to
                  flush (29686198 bytes in queue)
If it’s dude related, this also happen to me when I try downgrading from 6.37rc to 6.36 but on x86
than upgrade again to 6.37rc fix the problem
but to be sure check tools-profile processes
upgrade to 6.37.1
watching this:
oct/07/2016 08:21:39 dude,critical queued 67725714 bytes for write to db. Please c
onsider faster storage otherwise out of memory condition or data loss can occur
but base locate on SSD.
WHY???
Report to the support
Same problem running on Proxmox SSD system, near 3% CPU usage and about 22% RAM usage
