Dude 6.43.7 reprobe problem ( service ping)
I upgrade from Dude 3.6 to Newest and have some problem.
When imported xml file was to Dude v6 then I have problem:
  1. Device witch was have service PING can’t chage status ( disable or enable PING) and reprobe don’t work. When service PING is OK and change to disable, then service status show ‘Unkown -2’ and ‘UP 4.29G’. After enable PING service it show ‘Unkwown -1’ ( but service PING FLAG is green) and try push repbrobe button and without success.
When device impoted was without service PING then reprobe and service ping working and status change.
When create new device - then it work too.
So where can be problem ?
Problem solved when disable/enable network map, then ping reporbe again and working correct,
