Dude 6.44.6 on CCR (shared) : can not connect to agent - corrupted database?
on my (shared, as in, not dedicated to Dude tasking only) CCR Dude installation, (CCR1036-12G-4S)
previously, on 6.,44.5 all seemed to work fine;
Upgraded to 6.44.6, all RouterOS devices can not connect to agent (including the device on which the Dude server runs).
(all devices give status
“connection to agent (agent-device name here) not ready (not connected, next attempt at xxxxxx), next attempt at xxxxxx” (xxxxxx are the time of next connection)
Tried unsuccessfully:
  • copying dude/files and dude/dude.db using FZ out to PC, deleting or renaming dude/files/default dir, restoring dude/files/default and db from PC
  • deleting the entire dude dir and re-enabling dude to re-create dir structure, then stopping dude to copy the db back in
In both above cases, devices are remembered, but can’t connect to agent.
What worked:
  • deleting dude db (I have a copy) and re-creating content by hand
So it looks like it corrupted its database?
Is there a way to un-break the database file so it’s accepted on new version again?
Kind Regards
el es
nudge
I am having the same issue on a CCR-1036-12G-4S also. v6.48. I’ve spent AGES building network maps - can’t bring myself to scrap it (27 remote sites), and start again!!! Please, can anyone help?
