Now when we have WinBox 64-bit, I’d like to see The Dude 64-bit client as it’s like the only thing that stops me from upgrading to MacOS Catalina.
Can we expect it soonish?..
+1
…and a Dude server with 64bit counters, please ![]()
-Chris
+1 same situation with Catalina. The dude running within Wine is a huge asset for me daily.
We definitely need this for MacOS Catalina. Any ETA yet?
+1 from me, I’m blind without Dude on Catalina
+1 from me, Still waiting fore dude64 before upgrading to Catalina
People say The Dude is frozen again, so looks like Dude64 won’t happen any time soon ![]()
Both the dude client and winbox works with Crossover. I also build the app with Wineskin winery, you can download them from my cloud:
The dude
https://www.sergioaletta.com/owncloud/public.php?service=files&t=5168c6bcf61e2c9e1471166b1668e321
winbox
https://www.sergioaletta.com/owncloud/public.php?service=files&t=4de30696c3ed2902d08ef6f64aed6596
You mean, Wineskin on 64-bit systems can run 32-bit applications?
+1 Also does not allow to update and dude is closed, the problem is relevant both on Windows and under wine a similar situation.
P.S I solved this situation by reinstalling, but it is bad that the update does not work as it should.
Good afternoon. So what about the 64 version? Will it be or not? I really need it !! A year has already passed since the last post.
dude and winbox work great in Crossover on MacOS, even om M1. Crossover rulez !
Well, bunt not quite such. I can run Winbox64, but Dude client won’t start. Mac OS Monterey, Intel Core I7, Crossover 21, Win10 64bit bottle.
It does work if you right click and run with options. See: https://www.codeweavers.com/support/forums/general/?t=27;forumcurPos=50;msg=245619
Crossover 21.1 has fixed The Dude ![]()
Whenever the dude will be remade for Routeros v7 I think that would be a great opportunity to recompile it for 64bit as well.
