Dude adding RouterOS Device Issue
I just bought a brand new HEX S / RB760iGS / Revision r2. (Factory Firmware was 6.47.10) for my home.
I upgraded the Firmware, RouterOS, and Dude all to version 7.2.3.
I can connect to RouterOS via Winbox and Dude via the Dude Client from my windows machine.
Winbox and Dude are running and accessible.
I run Discovery against the LAN, using the default network range of 192.168.88.0/24
It detects my router using the default IP of 192.168.88.1 but it does not have the RouterOS integration.
I have entered the user admin and my new password and it will not connect. it just retries every few seconds.
If I add a routeros management service for a service monitor other than ping, that fails also.
Do I have to setup a firewall rule or something for dude on my hex s to talk to winbox/routeros on the same hex s?
Without seeing the configuration of the device, can be all.
Do an /export of the configutration and put it on forum.
I only removed my lan dhcp static addresses.
I figured out last night that I could add 127.0.0.1 to connect via loopback but that doesn’t seem very clean.
Do I need to add a bridge as a loopback interface with a address assigned to it that would be inside my address space of 192.168.88.0/24 and then add a firewall filter to allow the traffic to the winbox port?
# jun/08/2022 08:28:09 by RouterOS 7.3
# software id = XM8X-JNU6
# model = RB760iGS
# serial number = HCF08A3293V
add admin-mac=18:FD:74:0A:1D:0D auto-mac=no comment=defconf name=lanbridge
set [ find default-name=ether1 ] name=ether1-ISP1
set [ find default-name=ether2 ] disabled=yes name=ether2-ISP2
/interface bonding
add mode=active-backup name=wanbonding primary=ether1-ISP1 slaves=ether1-ISP1,ether2-ISP2
/disk
set sd1 disabled=no
set sd1-part1 disabled=no name=disk1
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add address-pool=default-dhcp interface=lanbridge name=defconf
/lora servers
add address=eu.mikrotik.thethings.industries down-port=1700 name=TTN-EU up-port=1700
add address=us.mikrotik.thethings.industries down-port=1700 name=TTN-US up-port=1700
add address=eu1.cloud.thethings.industries down-port=1700 name="TTS Cloud (eu1)" up-port=1700
add address=nam1.cloud.thethings.industries down-port=1700 name="TTS Cloud (nam1)" up-port=1700
add address=au1.cloud.thethings.industries down-port=1700 name="TTS Cloud (au1)" up-port=1700
add address=eu1.cloud.thethings.network down-port=1700 name="TTN V3 (eu1)" up-port=1700
add address=nam1.cloud.thethings.network down-port=1700 name="TTN V3 (nam1)" up-port=1700
add address=au1.cloud.thethings.network down-port=1700 name="TTN V3 (au1)" up-port=1700
/port
set 0 name=serial0
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,rest-api
add bridge=lanbridge comment=defconf ingress-filtering=no interface=ether3
add bridge=lanbridge comment=defconf ingress-filtering=no interface=ether4
add bridge=lanbridge comment=defconf ingress-filtering=no interface=ether5
add bridge=lanbridge comment=defconf ingress-filtering=no interface=sfp1
/ipv6 settings
/interface detect-internet
set detect-interface-list=all
add comment=defconf interface=lanbridge list=LAN
add comment=defconf interface=wanbonding list=WAN
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.88.1/24 interface=lanbridge network=192.168.88.0
/ip dhcp-client
add interface=wanbonding
/ip dhcp-server lease
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
/ip firewall address-list
add address=192.168.88.0 list=LAN
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/system clock
set time-zone-name=America/Los_Angeles
/system gps
set set-system-time=yes
/system ntp client
set mode=broadcast
/system routerboard settings
set auto-upgrade=yes
/system scheduler
add disabled=yes interval=1m name="renew wan dhcp lease" on-event="/ip dhcp-client renew [find interface=wanbonding]" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=jun/05/2022 start-time=11:34:29
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
must be
add address=192.168.88.0**/24** list=LAN
but the address-list is never used
I do not see any line of config about dude… like
/dude
set data-directory=/disk1/dude enabled=yes
You sure you have installed and enabled it?
The firewall rules are stock. I didn't modify those.
Here is the bits for dude I did have it turned off. my bad.
I do have it relocated to a sdcard.
/dude
Any ideas?
The Dude server is not good at monitoring itself. You need to use another device as an agent.
