Dude and CapsMan monitoring
I’ve the TheDude running and I’m getting Telegram notifications when a device goes down, this works perfectly.
Next is that I want to monitor if the Mikrotik AccessPoint (AP’s) are connected to the CapsManager. At a number of occasions the AP is not connected anymore to the CapsMan but the AP is still online, connected to the network.
How can I monitor that the Caps client/AP is still connected to the CapsManager? Any suggestions?
Made some progress myself, I need to make use of the ros_command.
With the next command I can collect the amount of registered CapsClients:
ros_command(“/caps-man remote-cap print count-only”)
Next is to add a Probe using this function and that is something I’m not able to do yet. I don’t understand the “Available” and “Error” fields. Any suggestions on how to check number of CapsClients?
Found the solution :slight_smile: Sharing it in this post so that I could help anybody else searching for a similar solution.
I created two functions to retrieve the number of Caps Clients and the number of Caps Radios from the Dude server.
Then I created the two Probe items.
And then I added the two Probe items to the device.
This now monitors the number of caps clients and radios, when dropped below the value I specified I get a notification and can check what the issue is. Great extension of the Dude monitoring.
