how can i save data from dude to microsd on rb433ah?
thanks
thanks
not yet, but it’s planned
so now is microsd on rb433ah for nothing? ![]()
in 3.10 yes, but in 3.11 it will work as a proxy drive
what is maximum size of micro SD that work ?
no limit
Are there any speed or type requirements for microSD?
Can you provide some “tested and good” types?
We tested Apacer 1Gb and Kingston 512Mb
I’ve just updated the wiki with two more cards for the 433AH.
http://wiki.mikrotik.com/wiki/Supported_Hardware#Memory_cards
Would also be nice to upload ROS updates to the microsd so that clients can be upgraded directly from the AP’s Dude server.
Providing relief for our backhauls.
Does dude stores its database on recent versions of rotueros?
And do i need to format microsd somehow?
I think my sandisk 4g class 6 card doesn’t work. I don’t see more hdd capacity ![]()
dude doesn’t support external memory cards just yet.
ok, i bought apacer 1gb card. I put it in rb and how can i determinate, that it works? I see total HDD size 61.4 MB Do i have to format it in ext2 or something, to get it working? It is listed in supported cards list.
EDIT: emm i figured out, how it works. So it is for webproxy only?
When will dude support microsd? 4.0 beta1?
Problem is, that i have only 5 Mb left out of 64 and i cant export database, beacause internal flash fills up and then dude stops working for some time… and export file is not full. So i can’t export my database to x86 ![]()
