Dude and SSH
several weeks ago I installed Dude and set up monitoring of Mikrotik based network. Since that time I have been experiencing difficulties accessing SSH of some Mikrotik routers. In every few days router stops responding to SSH connections. Only solution to that error I’ve found so far is to reboot the router. After reboot SSH is working correctly again (until it fails again in couple of days). Before installation of the Dude server the MT routers were working correctly for more the 2 years.
Can anyone help?
Petr
Maybe just set the SSH probe interval to 300 seconds instead of the default 30 seconds.
SD
I would say most queries I would like to set to 5 minutes. It seems I can change the polling on all service under settings - polling, or I can change an individual servers settings. I would like a per protocol level of default
i.e. http 1 minute
ssh 5 minutes
ping 30 seconds
but I am not finding a way to do it.
-J
Is this a bug on The Dude 3.4? We have a big network mostly build from Mikrotik’s routers and when we made an upgrade from The Dude 3.2 to The Dude 3.4 we have a problem with SSH…anyone has a solution? :confused: :confused:
