Dude and Windows8
In windows 8 don’t work ping probe. I’m turn of embedded firewall also don’t work.
Disable UAC and run dude as admin.
Does not help
I don’t have w8 for testing, I will hopefully never run it but try to set “compatibility mode”.
Well… that’s strong argument for a new version of Dude :wink:
Not working
Just to be certain… You are running the dude on windows 8 that is in beta? With the metro interface?
Do you like it?
Erm… Windows 8 has gone gold and RTM few days ago already. Wake up lebowski :wink:
ugg
The same problem, guys! Windows 8 Pro, Antivirus and Firewall is off, UAC is off, installing and running Dude as an admin. When i add a new device it starts pinging but The Dude says “unstable”, then “fail”. Pings from the PC itself are ok. Any ideas?
