Dear all,
I have dude 2.2 for monitoring my servers and routers. Then i upgrade to version 3.4 with upload the backup.xml i got from 2.2 to 3.4. But the strange is the device began to auto acked themselves. Is there any suggestion?
thx,
ferry
Dear all,
thx,
ferry
2.2 and 3.x export/imports don’t seem very compatible, I had to recreate my whole installation when moving to V3.4
Regards
Paul
hmmm. ic. so the point is i must create all that things from the beginning huh??? oohhhh.. my goodness
Yes, well, some stuff works some stuff doesn’t, and the problems I am now having with V3.4 could be related to some left over objects in my Dude database, I’m not sure.
I would start from scratch, I know it’s a huge effort, but for what it’s worth I think you would be better off.
Regards
Paul
Dear all,
i have already create new on dude 3.4. I run both dude 2.2 and 3.4, but the client seems to be autoacked in 3.4. Something wrong in dude 3.4??
Please advice..
Thx,
Ferry
