Dude Beta 5 issues: No shadows and MAC addresses
I upgraded from V2.2 to Dude Beta5. After upgrading, I have found two issues so far:
  1. Map shadows are not displayed. I can select/deselect the option and nothing happens.
  2. When peforming an SNMPwalk on devices, the MAC addresses are displayed as a couple of special characters (Mikrotik routers included). V2.2 and before, they were correctly displayed. Was something changed with the display of MAC addresses? Works fine from the CLI using an snmpget.
  1. Yes we are aware of this problem, thank you.
  2. You should check that you have added a MIB for oids that contain MAC
    addresses. It should work.
#2: I do. It works in V2.2 . When I load V3B5, the MAC display is messed up (this is with an SNMPWALK also). Go back to V2.2…all is OK. I see a bunch of MIBs were added in V3. Which MIB takes priority: The one that is in V2.2 that being upgraded or V3 that come with the install?
show us a picture of the problem. What oid exactly it is? From which MIB?
The MACs from a 532/564 MT…all are messed up. I can post a pic later if you want.
