Has anyone else seen / fixed this before?
Thanks in advance
Thanks in advance
Just modify the hdd_usage function. Take the result, multiply by 100, round (will remove to nearest integer) and then divide by 100. This will give you two decimal points. You can multiply/divide by whatever you want to get the resolution desired.
Thanks, Can you please give a working example of that?
edit the hdd_usage function. Using the example below, subsitute current_function with the existing code in hdd_usage and save.
(round((current_function)*100))/100
This is under probes - hdd?
Ok, when i do as you say around this segment of code
(oid(concatenate(“iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageUsed.”,
array_element(
oid_column(“iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageIndex”, 600),
array_find(
oid_column(“iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageType”, 600),
“iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTypes.hrStorageFixedDisk”
oid(concatenate(“iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageSize.”,
array_element(
array_find(
like so
(round(oid(concatenate(“iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageUsed.”,
array_element(
array_find(
array_element(
array_find(
)))))*100))/100
it doesnt work, the dude just displays [device_function]
IF this is hdd_usage:
array_element(
array_find(
Then replace it with:
(round(((oid(concatenate(“iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageUsed.”,
array_element(
array_find(
)))) *100))/100
After saving, ensure that the error column is blank and not reporting any issues with the function.
i have, see what ive posted above
I don’t have access to dude at the moment. Is hdd_usage this entire piece:
array_element(
array_find(
array_element(
array_find(
then it would look like: (you are missing parens in yours above)
(round(( (oid(concatenate(“iso.org.dod.internet.mgmt.mib-2.host.hrStorage.hrStorageTable.hrStorageEntry.hrStorageUsed.”,
array_element(
array_find(
array_element(
array_find(
)))) )*100))/100
that doesnt work. it just comes ip with device_performance
Does it show an error in the error column for the function?
This code works for me:
(round((
array_element(
array_find(
array_element(
array_find(
)*100)/100)
That worked a treat, thanks alot! ![]()
