Hello all,
i`m new on MikroTik / RouterOS
Today i have installed Dude. On the Router Port 8291 is open (nmap say`s)
My WIN Firewall has an exception for Dude
But, I can’t get a connection. What can I do?
Hello all,
Can you please check steps from the manual
/dude print
Port 8291 is used by WinBox and Dude as well.
If you still have this issue, I have posted a similar issue, and here is the update, hopefully it is the same solution:
run this commandon the windows client machine:
netsh interface tcp set global autotuninglevel=disabled
