dude client charts bug
Hi all!
I use TheDude for several years, sinse version 3.6. Now old dude db imported into 6.x, current version used is 6.35.
Once i changed keep time of charts on server (Settings → Chart) and now while watching graphs on links dude client takes about 50% of cpu usage, its windows doesn’t answer. Servers system:resources shows ordinary values.
I try to find the reason: uncheck “Graph Bit Rate” → OK, then open link history again and check that chekbox. Now it works fine, but I loose all the history for this link…
I have a lot of such links and i don’t want to lose all their history. What can i do to solve this problem?
Download the database backup first before you change anything to prevent precious data loss. Try vacuum.
