Is there a a way to customize the fields on the client side of dude that allows you to add the customized feilds 1,2,3 from the server general tab to the client side. I would like to put the cutomer contacts in those feilds for quick access and would like to view it on the client side. Thank you
Why not just add it to the notes field? I don’t know how to use the custom fields…
