Dude Client on RB400
I installed the dude client on 3 different 400 series routerboards. rb450G, rb493 and rb493AH. In my main dude server I added each as a Agent and they do not connect. If I remove the password then the server connects to the agent with out a problem, but as soon as i add a password it does not connect.
I have also tried adding a username dude and no password but the server wont connect to any agent not using the admin username.
I Have also tried using an agent on a RB1100 and the same issue occurs.
RB1100 is running 5.0 and the RB400s are running 5.14
Any suggestions?
Thanks.
Friend you have the dude package for rb450g and 493g?
Friend, sorry, I can not speak English, I’m using google translator, in my business I could do works, installed the package on the dude 3.6 RB1100, put a User and Password, and in my windows server the same version of the dude 3.6, I set up snmp, and choose the device snmp and the agent.
