I need to perform dude server on RB1000 but a problem has arisen. HDD space is not enough!
I´ve installed a 4GB CompactFlash 4x into the external CompactFlash slots in RB1000 and it has been detected and formated by WebProxy but what I really need is to use that memory card with Dude Server.
How can I do it? CompactFlash memory added does not appear in >system resourses print
Moreover, when I try to add an image (on the dude background for example), the file is transferred to the HDD memory making the HDD Free space smaller.
I cant find the new memory installed. However, RB1000 Brochure says that WebProxy, UserManager backups and Dude Server can use memory card.
I just did exactly this a few days ago.. Works brilliantly. In fact, At first I installed Dude on the internal storage (NAND), but this caused the sector writes to shoot up by 12,000,000 every day (yes, 12 MILLION)… which can’t be good for the NAND. I stuck in a CF card and moved it to it from the Stores window.
/store> print
Flags: X - disabled, A - active
# NAME TYPE DISK STATUS
0 A dude1 dude micro-sd active
1 web-proxy1 web-proxy system backup
2 dude2 dude system backup
