When upgrade DUDE from beta1, Dude crash with old DATA.
Bye cuccio
Bye cuccio
the configuration files from older betas may not work correctly that’s why I suggest you to do a configuration reset.
Click on the ‘Server’ there is a ‘Reset’ button - that will reset the configuration. After that it should work fine. If not then please tell us what you did before it crashed, also if there is an error message then please write that down too.
