It seems everytime I click + add device and add the a mikrotik device to my map and then later double click it to add services, names, etc. it just hangs. So I have to wait and wait and then the dude closes with not responding in Windows XP. But If I use the discovery method, this never hangs and I can double click on the mikrotik device just fine. Has anyone else ever encountered this? I have tried this on 2 separate pcs now and same results.
After you add a device it tries to SNMP discover services. Sometimes it detects 4.9g of unknown services if you wait a very long time. Delete the device and then click undo “top left” button. This fixes the issue, select the correct snmp string in the settings of the device then add services.
Thanks for the reply, I think I have figured it out now.
