Dude crashes when DB reaches 2 GB
Good Morning
we’ve got a problem with our Dude. It crashes every time the database reaches 2 GB. It’s a NTFS system (even Fat32 should have a limit of ~4 GB). We’re doing a nightly VACCUM on the database, which doesn’t help either.
The dude is running as a Windows service and the main problem is: it won’t come back after it crashed. We have to get a backup everytime this happens.
Any ideas?
Reduce your Raw Value Keep Time to 2days. Change polling from 30 seconds to 60 seconds, half as much raw data. Hopefully it will run long enough to reduce the raw values. Change other values in the server settings chart so that your approximate storage size is below 1500kB.
HTH,
Lebowski
Thank you for the tip. I changed those values today. Let’s see how long it works this time.
