Hi … do not know if anyone has had these cases …
DUDE recently installed 3.6 on server … but we are giving the RB device is dropped or down the Disk and CPU, but if RB has entered the unsaturated or the Disk or CPU, ah to be or I fallen shows such services …
thank you
Confirms whether SNMP is active in RB and is marked on RouterBoard The Dude.
Hi Leo Vieira
all my RB have the specific snmp and DUDE I have a windows server
the dude is configured with specific snmp using my network
the problem we have for example; the dude shows me a RB with disk and cpu graficamentye fallen and displays, at that moment the nagios send me Alert Fallen RB for the minimum time, and cacti sample packets lost me at that moment …
No that will be with me and that has network problems …
Thank you
Hello good friends .. with the new version 6.34-RCXY the -DUDE- everything works ok.
This CCR1009 and a x86 and it works fine ..
but I have a query in version 3.6 could do backup of my settings and networks; and in version 6.34 does not show the option to backup or export ..
anyone know about it
It’s now a command line task on the DUDE Server -
http://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/DB_import_export
/dude export-db file=(file_name_path)
yes , but don’t work with .xml file
Next rc build should correct xml backup import problem.
