I’m Really Frustrating I was reading mostly all the posts about dude version for linux since 2010
with all the mikrotik upgrades and developments
they did not reach the point to be meet clients request and give them a dude platform that is compatible with the linux environment
the answer i read from the support is windows users are more then linux
is this really what mikrotik solution reached after all this developments
even for the winbox
i hope that mikrotik team will reach to give us there services supporting all platforms since all there supports in the mum use mac book its an irony here
please make for us dude and winbox that is compatible to linux
thanks
Dude and Winbox can already be run on Linux/OSX systems not only Windows.
From The Dude wiki (https://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/Installation#System_requirements_for_client):
The Dude client should run on pretty much all of Windows versions starting with Windows XP. Client program does not require much resources so low spec windows computers for monitoring needs will do just fine.
The client can also be used on Linux and MacOS if using Wine or Darwine respectively> .
Same applies for Winbox.
There’s no more support for wine 32 bits on any standar Linux OS distribution. Please, give us a 64 bits version,
You know what would be great …
Some actual step by step instructions on how exactly to get DUDE client running on an Intel Linux x64 OS with wine.
Anybody?
It’s even strange, the Mikrotik itself is spinning on Linux, but there is nothing for Linux …
Have to use different crutches…
