Dude fresh install doesn' connect
Ia just got two CCR1009-7G-1C-1S+ and I have installed and enabled dude server, but when downloading the client and trying to connect, it just says connecting but nothing happens. Any idea what is going on?
Running 6.40.1
Cheers.
I forgot to say that I can winbox and ssh from the same client to the server.
titansmc,
To what port do you trying to connect?
Thank you!
First of all you need to check is enabled dude or not by simple command in 1009’s terminal:
[admin@MikroTik] > /dude print
next step - checking services:
3rd: try to telnet on your winbox-port:
telnet mikrotikIP 8291
4th: check your dude server and client versions, they need to be same
Same here. Dude 6.40.1 on CCR1009-8G-1S-1S Dude is running on the CCR and I can see netmaps in Webfig/#Dude
8291 Port is listening on the CCR - I can telnet to it from command prompt and it’s “open”.
If I try to connect to the CCR with an older version of Dude client i get prompted to update to version 6 so IMHO the problem is not the server it is the client side.
Mikrotik please fix.
My issue was resolved by not using Windows 10 for the Dude Client. Windows 7 works, Windows 10 appears to not work.
Zod,
Did you tried this solution DUDE server cannot upgrade from pc?
I have one CCR1009-7G-1C-1S+ and I have installed and enabled dude server and hotspot on the device, I then installed Dude client on Server 2012 R2 but when trying to connect, it just says connecting but nothing happens, untill i disabled the hotspot on the device , the Client dude now displayed on the server 2012. Please what can i do to solve the problem ?
