Dude has inability to ping - local problem
I have Dude running under Wine in X. It seems that Dude can not ping anything and only gives me as much information as “local problem”. If I su to that user I am capable of pinging.
Does anyone know what I can do to fix this problem or tell me what the problem is?
Note I am only using ping problems and RouterOS ?probes?. The RouterOS logins are working perfectly fine and continue to poll information.
Thanks in advance!
Note for Linux users: you should start the Dude from the root user (or delegate some permissions to your regular user), or else the Dude will not be able to ping hosts.
http://wiki.mikrotik.com/wiki/Dude_usage_notes#Getting_Started
See http://forum.mikrotik.com/t/starting-dude-on-linux-upon-boot/22936/6
did you fix this?
