Hello is there a way to use Dude in a routed scenario somenthing like this:
internet–>Firewall–> Dude -->AP routed CPe
–>AP routed CPe
–>AP routed CPe
some advise?
cetalfio
I’m not sure exactly what you are asking. The Dude works perfectly in a routed environment to monitor CPE or AP devices. If you are trying to monitor remote devices behind a masquerading Mikrotik router, just install the optional Dude.npk package and set it up as a Dude agent for those devices behind the remote firewall.
Hello Cetalfio.I can not understand your question what did you want to ask me.But you install the the dude again and i hope your problems solved.Just install on the firewall version not others.
