Dude incomlete applications server higher ver & firmware Dude RouterOS 6.33.1 compatible.
Good afternoon! need technical information on installation dude. In older
versions, such as the installer dude 4.0, and was part of the client and
server application that allows you to install it on the remote server
computer. In your new ver. I found only the server part of the application
to be installed on a separate router and the client portion on the PC.You
do not produce a universal installer that contains the complete and server
and client side, for installation on the remote server computer? If you
produce, please give a link to download the full-length versions of these!
Also, I can not figure out if my router supports mikrotik (MikroTik
RouterOS 6.33.1 (c) 1999-2015) setting dude server from this page. Many
thanks
You should read the correct threads and manual pages. The dude server v. 4 was discontinued but new server package is available for 6.34 and newer releases. Runs on tilera, x86 and CHR only. There is no windows version of server. The client is windows application like before. Hope you have got it.
I also hope that the MT will make a new installation package of the server for windows…
