Dude Installation
Dear Colleagues,
I have install dude and after installation, my devices go red. I can ping all subnets and networks but don’t know why I’m having such issue. I have used Dude 4.0 beta1 for such.
Juicz17,
Which probe do you setup on on your device and what is their status?
Device → Right click → Settings → Services
Thank you!
slech,
I used ping which is a ICMP protocol.
Juicz17,
Only ping check on device and what is it status?
Thank you!
Slech,
I can ping all devices I added to my dude. My issue is all devices goes red 10 mins right after adding them to the dude.
I will do a continuous ping for the whole day and those devices are reachable but pinging them through the dude won’t be reachable
Juicz17,
This video show how we added all our devices and all of them UP: https://youtu.be/ZnmFz_j_PeM
We use Dude v6.
May you try a latest beta - 4.0 beta3 (dude-install-4.0beta3.exe)?
Thank you!
This is old Windows version bug/feature. Summary recommendation - try to launch Dude with Administrator. But it was not works for me in Domain and I simply check other services. Now we use DudeV6 - ping works perfect.
I am using Dude V4.0 Beta3 and like you guys said, I will lunch dude as an admin and get back to you guy.
Thanks for the head up guys…
Guys,
I lunched Dude as an Admin but still issue isn’t resolved and morever I’m using dude Version 4.0 beta3.
I appreciate your effort and thanks…
Juicz17,
On what Windows version do you installed Dude Server 4.0b3?
Hey guys
Window 7 professional 64bit
