What is the question? Do you want to open a new tab? You will need to check firefox command line options. Maybe use chrome, it has a “application” mode. Click tools options, application shortcut (then you will not have to specify the url).
the question is - if I can do it without the firefox?
directly from cmd?
I tested the solution with Firefox and unfortunately - dude crashes
I’ll check it with Chrome.
I thought cmd will have something like file_get_contents() (in php) the effect is as if I visited the web page.
Unfortunately, i tried this in FF and Chrome and all i got was a fatal error and dude crashes.
To tell you the truth all I really want to do is send information to the server what service is running and what does not work.
It would be great if I have access to the Dude Services tab from outside
I would like to retrive the device name, type of service, and information on whether the service is running or not.
I thought that if the notifications execute a link to an external server, I would be able to store and proceed with this information (send sms, email or ignore)
