Can I install The Dude on my Mac?
Only a Windows version is provided, but you can try using Wineskin:
http://wineskin.doh123.com/
I use it with WINE through MacPorts.
i tryed wineskin, it install perfect and runs, but stuck in conecting to server…! seems that the local server dont start
change local server to 127.0.0.1
works perfect, but only if connect to a remot and change de ip as you told, thanks…
