so, make a new map for each of your networks. when discovering - specify the Agent that you will use. Agent is the device that does the monitoring - ie. Dude Server
It seems I end up answering my own questions! In case anybody else wants to know I will explain how I set it up and anybody can help if there is a better way.
Make sure the agents you want to use have the dude package installed. Then in dude go to settings and add the agent with default admin and no password. Or login to that router with dude and create a password under admins. There might be an easier way.
When the agent is setup you can go into dude and double click on the device and choose which agent must monitor it.
I can’t really see that it took any load of the links I hoped it would.
Put less things on your device labels, set your label update interval to a longer time between updates, Set services to ignored for the ones you don’t really have to have. Don’t use auto discovery or set the interval to a long time between.
How much bandwidth is being used by polling?
My server looks like it averages about 500kbsp using mostly ssh, telnet, ping, and a few others with nothing but the name on the label.
