dude on rb433ah
ok i installed dude on the RB, but where do i find the config options???
connect to the IP address with the Windows Dude program.
i get login failure, using the same usr/psw then winbox
do i need to do anything special on the rb to allow remote connection on that port?
Hi, default username for Dude is “admin” and password is blank, even if You have different UN and PW on Your RB.
sweet thank you
i would not recommend dude on rb433 unless you are going to use it solely for the dude monitoring function, it uses resources
