Dear community,
I installed The Dude 7.4.1 on a virtual routeros (proxmox). Since I am using Mac OS besides of Linux and there is no 64bit support, I really would like to access the MAP function inside the Webserver (or Winbox). The documentation (https://wiki.mikrotik.com/wiki/Manual:The_Dude/Server_settings) says that it should be able to configure a webserver in the Server Configuration Tab ob The Dude Client. I do not have that option. The documentation says “Port - port of the running web server. Might need to change if something else is running on port 80, or for security reasons. Note! if the Dude server is running on RouterOS, the port is 81 and can’t be changed.”
I do not have that port available:
Welcome back!
[admin@MikroTik] > /system/telnet 127.0.0.1 81
Connecting to 127.0.0.1
telnet: connect() failed: Connection refused
Port 80 works (WebFig etc.) - but there is no application under /dude.
What am I missing? Thank you very much in advance,
dmq
