Dude on Windows server 2003 problem
I have an issue. I started a config file on a windows xp box and then decided to move to a server 2003 box. I exported the data form the windows xp box into the xml file. I then proceeded to install the same version of dude on the server 2003 box and check the reset data box even. I went ahead an impored my backup and everything went well excpet the network map now doesn’t have any lables like the name and such. All is there is the up color ( green) i box shape, and the icon I picked out for the device. I looked at the settings and they are set to display the name and ip address of the device but nothing. I have even tried to change the display variables and still nothing. Everything is listed in the Device list as it should be but the map just doesn’t have any labels. Any help on this would be great for I have a few hours into configuring it.
Maybe you changed the font you are using for labels and you have that font
only on your windows xp machine?
It would help to investigate the problem if you send us your export file
(support@mikrotik.com)
