hi i download the dude v6.39 and i say not connected
Hi. I did the same and I say it is connected.
kadhim09,
Did you specify IP address of the dude server?
i have problem with start the dude it say not connected and the server is localhost
kadhim09,
Starting from Dude v6 it is no more Windows server exist.
In such case you should connect to the Dude server installed on Router OS, for example on your RouterBoard.
You should specify RouterBoard IP for connection.
Thank you!
hi guy i need a help please i want to add dude-6.39.1.npk on my mikrotik os but it doesn’t work after multiple try.
my os is at the last version 6.39.1 but the dude is refuse to instal on package contents.
Are you installing it at supported architecture?
