Hi
I’ve just started using dude (v1 and now V2 beta). It works great but about every 15 mins the client seems to loose connection to the server and starts reporting everything is down, even my own computer.
I have both the server and client running on the same computer (mine) and have the server running all the time.
The server button at the top of the screen always shows green and disconnecting and reconnecting doesn’t help, but restarting the server fixes the problem for another 15 mins.
If I keep the server running all the time and shut down the client for several hours, the server seems to be tracking evrything properly as shown by the event logs when I restart the client, but then again, the client reports the whole network is down in about 15 mins.
If I change the polling interval, for say my own computer, from the defaults to interval of 5 seconds, timeout of 2 seconds it only takes a few minutes before my computer is reported as “down”.
Any suggestions about how I can solve this problem?
Also with V2 beta, every time i change the settings for a device the event log reports a login and logout event. Can this logging be stopped?
GC
