New install Dude 6.39.2 is running on rb750glr3. I have 3 pptp tunnels, 3 pptp users, 3 routerboardos running 6.39.2. Dude can login just fine to router1 via user1 login, cannot login to router2 or 3 via those user names. All the settings were copied from a previous 4beta3 dude operation. Am able to login using default admin and password to all routers. Dude is not presenting on network map the correct config for the monitor and tunnels, half of 2 tunnels is missing (the two that have screwed-up logins)
Also getting a lot of dropbear msgs in logs on radios, 4x per minute in relation to the missing tunnel half.
