hello
It would like send sms from dude. I installed the dude on a mikrotik as a package. On this mikrotik usb port is an gsm phone. (the /tool sms send … working from console)
How can I send sms from the dude? (device up and device down)
I hope so understandable that ointments
We have the Dude on a PC, and use email notifications. Most mobiles have a email gateway to each phone number. So if your cell phone is a verizon one and your number was 260-123-4567 you could have the dude email 2601234567@vtext.com and you would receive sms alerts. Does this answer your question?
i did taht it relayed but didnt get and sms
any ideas why?
is your operator Verizon? if not, you probably have some other address
i sow that after i havnt got a operator to do this im in southafrica
but thanks for the reply
In Denmark all the operators closed this feature about 8years ago… So no Email to SMS for us…
So if RouterOS can be a SMS GW for The Dude, it would be nice
if you can connect a phone to the computer, and you have some software to send SMS with it, maybe you can call this software from the dude with some parameters
Check out sourceforge for an SMS application that is GPL and does what you need…
http://sourceforge.net/search/?type_of_search=soft&words=sms
I use SMStools…
But would be nice, not to have another machine running…
I have received SMS Modem (Phone) Message via the Dude , but the message is only UP/Unstable state, not down state .
you probably configured it to send upon state change “Up->Down” but in real life this never happens. It’s Up->Unstable->Down
because not all services die at the same time.
So you need to change SMS sending to state change Unstable->Down
i´m new dude user and have a question:
our mobile carrier don´t have a email->sms gateway and we need sms notification.
Does it possible to write a RouterOS script in a RB493UAH to connect with mobile phone or modem in usb port, then dude (running in same RB) call for send messages ?
Is there a way for it?
Thanks in advance.
André
I know the post is old… but can you give me some advice for getting this to work.
I have installed SMStools and I am able to send SMS but I don’t know how to integrate this with The Dude.
Thanks.
