Dude server on RB-3011 CPU at 100%
When I enable the dude on a RB-3011 then both CPU’s are runniing at 100%./
Is this normal?
I’m running RouterOS 6.42.1
are you using external USB storage for the dude database?
No, all on the RB3011
But I see If I uncheck DNS lookup that the cpu us going ot 0 or 1 %
is better to use a usb external storage for that
you wear out internal flash memory with all the intensive writes of monitoring database
How many devices are you polling in the dude?
I had a RB750Gr3 doing about 20 devices and experienced the same issue.
Setting up CHR as a virtual machine sorted all the problems.
