Dude Server & Wine
I want to run dude server on linux, only the server part of dude, eg dudes.exe
I’ve installed xfree ,virtual frame buffer xvfb an wine.
I start dude with this:
wine dudes.exe
Invoking /usr/lib/wine/wine.bin dudes.exe ...
file dir: Z:\GATE\Dude\data\files\
load objs
xml final parse failed (1:0)
bad backup: xml final parse failed (1:0)
fall back to previous store
load map of: Log Entry (1000)
load map of: Log Entry (1001)
load map of: Log Entry (1002)
load map of: Network Map Element (1003)
obj count: 211
objs loaded
fixme:msvcrt:MSVCRT__sopen : pmode 0x01b6 ignored
Event: Dude started
Event: User admin logged in from 62.240.166.70 via tcp
I can connect, but the map window says “empty” and nothing is working.
I’ve tried the v 1.1 ant the 2.beta. Always the same, looks like something is not loaded. Anobody knows?
output looks completely fine, are you running ‘wine dudes.exe’ with root
permissions?
Because I don’t have a real screen on the router,
i just copied all the files, but forgot to import registry
settings.
Now it works just fine. :slight_smile:
