Hi
we are using Dude for monitoring our network. After we adding all devices we mentioned that labels data information periodically stops and the SNMP data stops too, and after while it works again. for example the link between a switch and a radio changes to :
RX: [Interface.InBitRate]
TX: [Interface.OutBitRate]
and when you open the link setting, you will see the SNMP data lost. After while it works again.
We read something about the issue in forums which was talked about changing the OID, but it was not helpful.
Is there anybody who knows how to solve this problem?
Thanks ![]()
