Dude Syslog BUG
Version 4.0 Beta 2
Adding a second syslog to this ALWAYS dissapears on close and reopen. The first syslog works, but adding one does not get saved.
This syslog bug is really frustrating. It`s mentioned here:
http://forum.mikrotik.com/t/bug-custom-logs-reseted-to-default-after-windows-reboot/37743/1
and now it`s not fixed even in beta2 version? Does it mean it would not be fixed at all in version 4? We also have dedicated box for monitoring numbered points, intended to use Syslog - every stations should have own log file.
With this bug every restart will cause much trouble, anyhow it`s not solution to have one enormous log file.
I hope you will find the way to solve this soon.
