I have a RB 532 running dude services, however, I can not snmpwalk any device from the server. I can from the local machine (don’t help).
Ideas suggestions.?
Ideas suggestions.?
Check out the devices and see if they accept SNMP connections from your RB 532. Often, for security reasons, devices only respond to SNMP queries from whitelisted IP’s. Perhaps your local system is allowed, but the RB 532 isn’t.
Well, kinda figured out my other issue, but not the SNMP walk issue.
I had another post that asked about getting a unknown interface under the link properites, if you don’t have the right username/password in the routeros on the node, it won’t work worth crap!
So I can monitor link speeds now via the routeros mastering type, so no biggy there.Still cant’ get the snmp walk though.
I did check the commmunity and the allowed addresses, currently it is 0.0.0.0/0 and still nothen.
Dennis
Fairly obvious, but… no firewall in between the RB 532 and the devices?
Yap, already checked that. Can ping without issues.
I have this problem also. I remember seeing another thread with someone having the same problems..
Every time a new RouterOS beta/RC comes out I load up the dude package on a new RB532 and test it hoping that it will have been fixed. If I get a chance I’ll try RC3 on a RB333 today and see if it’s just the 532’s that have the problem.
-Gerard
I just loaded the dude package on a RB333 running RC3..
After the package is installed and the router is rebooted I am no longer able to access the router on port 80. If I goto ip services it shows www as being invalid and not running.. I’m also unable to connect to the dude using the dude client on windows xp. It says that the connection was refused.
I did a /sys reset after upgrading to RC3 and installing the dude package.
[admin@MikroTik] > /ip ser pr
# NAME PORT ADDRESS CERTIFICATE
0 telnet 23 0.0.0.0/0
1 ftp 21 0.0.0.0/0
2 I www 80 0.0.0.0/0
3 ssh 22 0.0.0.0/0
4 X www-ssl 443 0.0.0.0/0 none
5 X api 8728 0.0.0.0/0
[admin@MikroTik] > /sys package pr
Flags: X - disabled
# NAME VERSION SCHEDULED
0 dhcp 3.0rc3
1 system 3.0rc3
2 X ppp 3.0rc3
3 X ipv6 3.0rc3
4 ntp 3.0rc3
5 X hotspot 3.0rc3
6 advanced-tools 3.0rc3
7 X routing 3.0rc3
8 wireless 3.0rc3
9 security 3.0rc3
10 routerboard 3.0rc3
11 dude 3.0rc3
12 routeros-powerpc 3.0rc3
[admin@MikroTik] > /ip ad pr
# ADDRESS NETWORK BROADCAST INTERFACE
0 D 192.168.10.226/24 192.168.10.0 192.168.10.255 ether1
[admin@MikroTik] > /sys telnet 192.168.10.226 80
Trying 192.168.10.226...
telnet: Unable to connect to remote host: Connection refused
Welcome back!
[admin@MikroTik] > /sys telnet 192.168.10.226 2210
Welcome back!
[admin@MikroTik] > /ip service set www port=8080
[admin@MikroTik] > /ip serv pr
1 ftp 21 0.0.0.0/0
2 I www 8080 0.0.0.0/0
3 ssh 22 0.0.0.0/0
[/size]
