Hi, I cannot get “execute on server” to run a script saved in the routeros, i’m issuing the command:
ros_command(“/system script run liga”)
Does this already work? Execute on server just got implemented back.
I noticed this in my log:
oct/02/2016 18:40:20 system,error,critical login failure for user admin from 127.0.0.1 via dude
oct/02/2016 18:40:20 system,error,critical login failure for user suporte from 127.0.0.1 via dude
It’s like The Dude is trying to log in his RouterOS host, i can’t understand why the failure from the admin user, the password is the same.
Tried the latest 6.38rc15, still not working. Guess I still won’t be able to migrate =/
If your user and pass are correct
Try New Terminal
user group print
0 name=“read” policy=local,telnet,ssh,reboot,read,test,winbox,password,web,sniff,sensitive,api,romon,!ftp,!write,!policy,!dude skin=default
1 name=“write” policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,sniff,sensitive,api,romon,!ftp,!policy,!dude skin=default
2 name=“full” policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,---->dude<— (This policy should be “dude” not “!dude”)skin=default
From version 6.36 is added new “dude” policy in user group
