since usage of dude V7, where to store routeros files for upgrading device from dude client ?
in V6 i was using /dude/files path…
the dude client do not show the files anymore…
what I’m missing ?
what I’m missing ?
Dude > Settings > Data Directory: indicates where The Dude files. In my case it is: disk1/dude-data
disk1/dude-data > contains the databases default.
disk1/dude-data/files/default contains the base files, sources, images and mibs default.
you should add your folders in: disk1/dude-data/files
Examples:
disk1/dude-data/files/fonts
disk1/dude-data/files/images
disk1/dude-data/files/mibs
disk1/dude-data/files/packages
It is possible that the files are not detected automatically, therefore you must reboot the device.
Note: For RouterOS upgrade through Dude to work properly you need to place the RouterOS upgrade files into {dude-data-directory}/files.
Don’t bother with 7.4.1 and even 7.5. You can’t upgrade from The Dude.
