jhg
1
Installed TheDude 7.15.3 server (my Cube 60Pro ac building bridge is on that version currently) and enabled it.
By accident, I installed version 7.16 of the client. It starts up, displays “Downloading Updates” and then immediately closes.
Maybe an “Incompatible version” message would be helpful?
Amm0
2
You need to run it administrator on windows - at least to upgrade/downgrade - since it wants to update it’s EXE, a normal user cannot do that.
(If using Wine on Linux/Mac, the update should work with latest -devel since wine doesn’t enforce replacing an EXE)
